Georgia Iron
- Joined
- May 6, 2012
- Messages
- 878
- Location
- USA - Georgia
- Occupation
- Concrete building slab and grading contractor
I received word that it has left the plant and is in route to the dealer.... Should be here next week
The EH system is also noticeably improved over my 2014 SV300. .
They delivered my 340 a couple days ago. Mine has EH controls. I cant go back to mechanical. The 440 had 90 hp just like these only they made it with a bigger motor, the 4.5. I agree they had probably more hp than you can use in a lot of applications but I loved my 440. I would not be with out the 14X17.5 tires. I think once you tried them, you feel the same. You can still wheel pack effectively with them, but they give you more dump height and the machine hooks up much better. It is much easier to access the power of the machine. Your 440 if it was a Series 3 which it sounds like you had was pilot, not EH. It used electricity to activate the aux. hyd. but not in the operation of the machine. Scary that a salesman said it was EH. Only if it was some prototype machine would it had EH in a 400 series body, and those machines get taken apart or destroyed and are not for sale.
The excessive idling with scr creates some injection issues. If you work the machine, you will never have an issue. If you spend a lot of time, idling around, than they want you to kick up the throttle to keep the scr working properly. I will look at mine but there should not be a DPF.
My SV300 was very stable with a full load in an 84" bucket with a backsplash. It is a .90 cy bucket, heaped it gets to an even yard. I could go to full height into a truck and it never got unstable. I expect even better with this machine. The bucket breakout is over 9k on the 340 and with the big buckets we run that will be an improvement over the 300 which was around 7K.
I ran a NH version of the 340 at the factory this Summer during a customer clinic. After stepping out of the machine I told them I was ready to buy it and I did, just in Power Tan. The EH control system was incredible. The best I have run. The refinements made in the system is very impressive and my SV300 was a 2014. It is still more likely to have issues than a mechanical system of course but they are just so nice to run that I am willing to accept that.
I am using mine backfilling a commercial building tomorrow. Looking forward to see what she can do with the frozen ground, and a lot of material to move.
