My Komatsu PC50UU-1 Engine swap W/Pics
uffex
Lincoln UK
Admin
Good day
Nice picts the portable workshop must have been a real plus, been a positive if the engine unit spun out with the counterweight.
Kind regards
Uffex
John C.
That's an impressive job of shade tree technology. I wouldn't have thought of using a trailer as a working floor. Those structural pieces remind me of racking used in warehouses.
djbobo
Utah
Electrician
Thanks guys
The canopy framework was from an overhead swimming pool put together end to end.
Had the tarp custom made to fit with 12" centered grommets.
Me after 4hrs of using a 9" grinder and cutting wheel to make that reefer engine to fit.
djbobo
Utah
Electrician
My short videos aren't compatible
Pic of canopy and pump plate adapter
djbobo
Utah
Electrician
I didn't mean to turn it into a workshop.
It was not easily moved.
My nephew picked it up and put it on the trailer with his little excavator :)
djbobo
Utah
Electrician
Engine bay after modification and engine mounts welded.
djbobo
Utah
Electrician
It turned out well. Thanks.
While I had the welder and grinder out, I did this the that 3 pole weak canopy.
Of coarse I had to try it out!
djbobo
Utah
Electrician
More details for flywheel to pump adaption
Thermo King flywheel dry fit for adaptor requirements shown with new Centaflex coupling - Top
Komatsu flywheel; Bad rubber @ 3300 hrs on a 1991 - Bottom
Green40
WA
Just did the same coupler r&r on my PC40. Not a bad job. At 6500 hours it looked like this. Rubber particles during stater replacement told me it was time for a new coupler.20230321_174444.jpg20230321_174450.jpg
djbobo
Utah
Electrician
Identical looking after failed too.
This is preparing the Thermo King flywheel to weld my adaptor to a flat surface.
I know you machinist out there will have a good time with this one.
uffex
Lincoln UK
Admin
Good day
Great photo,s guys save a thousand words
Kind regards
Uffex
djbobo
Utah
Electrician
Yes, I like pictures.
Here's more!
Welded, drilled and taped front engine mounts.
