Next Up Fuel System
We all know that almost all no starts are caused by fuel issues!!
So I set up this
Super Cool Fuel/Pump and Filter set-up.
I added an electric pump and kept the Mechanical.
I can switch back and forth with (2) 3-way valves.
The engine mounted filter is a smaller 10 micron that needed replacing way to often, so I added a marine Racor 30 micron pre-filter with a top screw cap accessible drop-in cartridge.
Teaser;
I threw in a couple of check valves to help keep lines primed.
Note 3 return lines.
IP=Injection Pump
CV=Check Valve
NV= Needle Valve (More about that later)
I can now circulate fuel through the 30micron filter (F1) with its water separator right back to the tank.
This can be done with either pump. It's handy using the electric pump to do this without the engine running. The standby pump will be 30 micron fuel polishing continually. Loving it so far.
That 10 micron filter (F2) is now lasting way, way longer.
Yes, I'm wearing socks only!
