My CAT 426 Project
As I recall, I used a pair of older Tinning Shears to cut this, better than scissors, smoother than razor blade or knives.
oarwhat
buffalo,n.y.
We own a 1995 416B . Just a heads up the tie rod end that hooks up to the steering cylinder can freeze up and snap the tie rod. It's non greaseable and when the rubber boot comes off it rusts and seizes. In hindsight we should have caught this and kept it lubed. It broke during a snowstorm of course.
edgephoto
Stafford, CT
Finally had time to work on my 'hoe. I am tackling a leaking wheel seal. Since the axle has to come apart for this and the bearing needs to be replaced I will do both sides and replace the brake discs while in there.
This project is dragging on and I need this machine soon to start a house build.
edgephoto
Stafford, CT
I'd put the chain further back on the fork when lifting that much weight. That fork looks like it's read to give up!
The fork extension does look bad. It really isn't. The extensions were given to my brother by a body shop up the street who used them to move cars around. He bent them. He has a much bigger forklift now.
I would put the chain further back but there is a hole in the spot so it was more secure. Besides I was not lifting it and carrying it around. Just using it to stand the axle up, which takes way less power.
Today I plan to take the top section of and start to teardown to get to the axle seal and bearing.
