Memories for us old truckers
crane operator
sw missouri
Yours said this crane was in your future and you wouldn't
need to transport it you can just reach across the state to get the job done
As long as you come along to do the bridle and hoist cable inspections, I'll run the thing. Looks like its got about 8 winches on it, but that pennant cable set up 300' up there is the one I'm going to need for you to inspect. Its only daily inspections.
Cheap "old" Geezer
RZ, the Big H is a bit pricey even as a intact cab, the lack of the remainder of truck discounts that back pretty hard!!
Your younger than me, so up the cat walk you go.:cool: That job of inspecting will keep you fit as a fiddle :D.
kshansen
Central New York, USA
was that an early 903 with aftercoolers
Not a 903 that's a 1710 the loader is a Hough 400 and despite having the manifold boxes for the aftercoolers I don't see any water lines connected. Worked on few of the Hough's and a few of the 1710's over the years.
One of the 1710's had a four cylinder Wisconsin for a starting engine that cranked the diesel through a belt drive that mounted where a electric starter would normally mount. That engine was in a Bucyrus Erie Dragline in a gravel bed near Horseheads NY. Dragline would scoop the gravel out of the pond and stack on the banks then after it drained out the water a 988 Cat would load it in to Mack truck to haul to screening and crushing plant for the Ready-Mix Concrete plant.
Cheap "old" Geezer
Beat me to it and did not see yours til mine posted. Did you have good luck with the ones you worked, we had nothing but grief.
