Like JY Noted, Guinea Green, I can still see that color in my head from working Macks!!! Good choice to NOT use it!
Glad to see you getting some progress done, every good body/paint mans shop I've been in has also looked like a mess. I see those spotless shops on the rebuilding tv shows, and I don't know how they get anything done.
I like the color, what's the interior color going to be?
It's channelling a 903 LOL!Fired it up and test ran it today for about an hour. Jakes tested ok set the rpm up to 575 at idle. Oil psi cold 42 lbs hot idle 20-22, that's all good. And power steering works.
Typical BC 855 smokes like hell cold and stutters Mel Tillis for about 10 seconds after start up then smooths out.
Now that's just down right mean!It's channelling a 903 LOL!
I once bought a '76 Pete conventional with a grenaded 903 for nearly nothing, it wasn't a bad looking truck. Figured I could sell the hood and some other stuff and come out ahead, before I got it home I ran across a wrecked cornbinder with a silver 8V-92... Made a few bucks on that crossbreed.That is mean
Nothing worse than a 9 o nothin
I always liked to hear that lopey stumbling startup. My 7FB Cat would do it too.
I liked lopey Detroits.
I just replaced the starter on my old IH yard truck with a Denso gear reduction starter, It doesn't do that ugga-ugga thing now. 400 HP BC 3 with STC. Starts... farts twice and runs smooth.Is this the type that the first compression stroke sounds like the starter is not going to make it, until it does, and then once you get it rolling over have to help it along with the starter until it catches enough cylinders to stay running?
And smokes like a chimney until you start to drive it.
Good ole days.
