Mack-Phase Two
Discussion in 'Old Iron!' started by Truck Shop, Feb 3, 2019.
  1. farmerlund
    farmerlund Senior Member
    Nov 23, 2014
    543
    Farmer/ excavator
    North Dakota
    Wow, that tank turned out nice. Do you have engine and trans ready to install?
    DMiller likes this.
  2. RZucker
    RZucker Senior Member
    Jul 7, 2013
    3,138
    Mechanic/welder
    Wherever I end up
    So you are going step boxes under the cab? Obviously one will be the battery box.
    DMiller likes this.
  3. Truck Shop
    Truck Shop Senior Member
    Dec 8, 2015
    2,469
    SE Washington St
    Both have been ready for some time
  4. Truck Shop
    Dec 8, 2015
    2,469
    SE Washington St
    Yeah I have two standard aluminum 4 battery-battery boxes that I'm going to convert into steps. I have access to a bunch of aluminum step material.
    Mother Deuce, DMiller and RZucker like this.
  5. DB2
    DB2 Senior Member
    Jan 4, 2015
    340
    Winnipeg MB Canada
    That is literally a truck built to spec. Kudos to you and your abilities. Also your knowledge of trucks is unsurpassed.
    Cheers
  6. RZucker
    Jul 7, 2013
    3,138
    Mechanic/welder
    Wherever I end up
    This is how it all started, me trying to keep up with Truck shop in the V10 Ford. He was on a mission. Got a lot more pics of the day he picked it up.
    The second pic is the Mack on it's way to it's new home. 20180610_075450.jpg 20180610_111448.jpg
    DMiller and Truck Shop like this.
  7. farmerlund
    Nov 23, 2014
    543
    Farmer/ excavator
    North Dakota
    Yep, that's going to be one nice truck when you are done. Looks like a 400 big cam? looks a lot like the one that is in the KW you did a drawing of for me. Did you totally rebuild it or is it a good used engine? My guess is you went through every thing. :D The black and silver detail looks great together.
    Truck Shop and DMiller like this.
  8. Junkyard
    Junkyard Senior Member
    Jun 5, 2016
    2,935
    Field Mechanic
    Claremore, OK
    Looking awesome. I’ve been so busy I haven’t had much time to catch up on HEF. Gives me a few ideas for the A-Car should I ever get a chance to get back to it!
    Mother Deuce, Truck Shop and DMiller like this.
  9. Truck Shop
    Dec 8, 2015
    2,469
    SE Washington St
    Thanks, but there are a bunch of damn smart mechanics on this web site. Especially when it comes to Cat stuff Nige and C Mark are pretty sharp.
  10. Truck Shop
    Dec 8, 2015
    2,469
    SE Washington St
    Correct, BC II 400 and a RTO12515 spd. The engine I disassembled and inspected, replaced liner O-rings, gaskets and seals, main and rod bearings. Cam and followers, heads, block, crank
    and pistons were in good shape. The gear box I disassembled and replaced a few bearings and resealed. Only had $1,150 in engine and $300 in the transmission.
  11. Truck Shop
    Dec 8, 2015
    2,469
    SE Washington St
    If you look at the photo below and picture in your mind the hood cowl seam moved back to where the middle of the vent window is. That is about 16", which is what I'm adding
    to the length of the hood. The hood will be roughly 76" long. Which leaves plenty of room to lower the air cleaners like the drawing below 00H0H_8r3DMW2sbnJ_1200x900.jpg Lowered Mac.jpg
  12. RZucker
    Jul 7, 2013
    3,138
    Mechanic/welder
    Wherever I end up
    I know you want be your own dog... but with a hood like that, a set of big dual pipes would fit the proportions well. :cool:
    DMiller and Mother Deuce like this.
  13. Truck Shop
    Dec 8, 2015
    2,469
    SE Washington St
    Twin 6" x 8' stacks free mounted from the cab.
  14. RZucker
    Jul 7, 2013
    3,138
    Mechanic/welder
    Wherever I end up
    Yessss! :cool::cool:
    DMiller likes this.
  15. Truck Shop
    Dec 8, 2015
    2,469
    SE Washington St
    Have run into a snag with the guy doing the body work----He hasn't done any work in two months. So he is done and I will retrieve the cab and parts, and see if I can find someone else
    worth a sh!t to finish it. But I'm not surprised really, few bodymen are very reliable most are fairly shiftless or drunks. It will probably set me back a good year now and actually I'm ready to
    assemble the cab, install engine and transmission then set cab in-place.
  16. RZucker
    Jul 7, 2013
    3,138
    Mechanic/welder
    Wherever I end up
    That sucks. I do know a guy up this way that is good. He took the crumples out of a Peterbilt hood and nose and you cant tell it was ever touched. Last I heard he had some serious surgery but should be good to go soon.
    DMiller likes this.
  17. kshansen
    kshansen Senior Member
    Mar 11, 2012
    7,114
    Central New York, USA
    Guess some of it could be from sniffing the fumes in a body shop! Just a quick walk through most body shops will have my head spinning. Can't imagine breathing that stuff for 8 to 10 hours everyday.
    Good luck!
    DMiller, DB2 and RZucker like this.
  18. Truck Shop
    Dec 8, 2015
    2,469
    SE Washington St
    For me that's not much of an excuse, with me you take a job you damn well finish it. But who known's I might just rat rod the rest of it to create a sharp contrast from frame to cab.
    DB2, DMiller and RZucker like this.
  19. RZucker
    Jul 7, 2013
    3,138
    Mechanic/welder
    Wherever I end up
    Don't do the rat rod thing... Please...
    DMiller likes this.
  20. Truck Shop
    Dec 8, 2015
    2,469
    SE Washington St
    I knew I could elicit a cringe with a rat rod. Actually it will all probably go into storage because of medical problems I have going on at the moment. And finding someone who can
    do body work locally is not easy. And I'm not going to ship body parts all over hell's half acre to get it done. I want to get it done and move on.
    DMiller likes this.
