Mack-Phase Two
Discussion in 'Old Iron!' started by Truck Shop, Feb 3, 2019.
  1. RZucker
    RZucker Senior Member
    Jul 7, 2013
    2,773
    Mechanic/welder
    Wherever I end up
    You know… I have never been part of somebody's avatar before. :cool:
    Mother Deuce and DMiller like this.
  2. crane operator
    crane operator Senior Member
    Mar 27, 2009
    3,263
    sw missouri
    Everybody's famous for something. Momma says: "show your good side to the world".
  3. RZucker
    Jul 7, 2013
    2,773
    Mechanic/welder
    Wherever I end up
    I enjoyed that day. Truck Shop is one of the best to hang out with.
  4. Truck Shop
    Truck Shop Senior Member
    Dec 8, 2015
    2,209
    SE Washington St
    That was a good day the one that started my misery :p
  5. RZucker
    Jul 7, 2013
    2,773
    Mechanic/welder
    Wherever I end up
    That was a good day.
  6. Truck Shop
    Dec 8, 2015
    2,209
    SE Washington St
    Fifthwheel is on, tail lights & electrical, air system finished at axles and air line stubs run to the front. Flaps and hangers are on just need to install outside tires/wheels.
    Picked up the fuel tanks and frame mounts today, clean and paint mounts and straps/polish the tanks which are 80 gallon. Plus mount the quarter fenders, photos coming.
    Junkyard, DMiller, Tugger2 and 3 others like this.
  7. Labparamour
    Labparamour Senior Member
    Sep 6, 2013
    333
    Washington
    Nice progress!
    Looking forward to the pics
    DMiller and RZucker like this.
  8. DMiller
    DMiller Senior Member
    Feb 22, 2010
    5,073
    Retired
    Using stub mounts for the 1/4s instead of a cross tube I presume, cleaner look.
  9. Truck Shop
    Dec 8, 2015
    2,209
    SE Washington St
    Photos of progress.
    Camshawn, RZucker, Tugger2 and 6 others like this.
  10. Truck Shop
    Dec 8, 2015
    2,209
    SE Washington St
    One more.
    Tugger2, doublewide, Hank R and 3 others like this.
  11. crane operator
    Mar 27, 2009
    3,263
    sw missouri
    That looks really nice. Drives are a set of take off rubber from one of the over the road trucks?
    Mount engine and trans first, or put the cab on first?
    Truck Shop and DMiller like this.
  12. DMiller
    Feb 22, 2010
    5,073
    Retired
    Sweet, very clean layout and efficient use of space!! Nice Holland wheel. Four wheel Maxi's, handy.
    Truck Shop likes this.
  13. Truck Shop
    Dec 8, 2015
    2,209
    SE Washington St
    Yeah those are all take offs including steer tires, just not going to put new rubber on a rig that will be lucky to see 2,500 miles while I own it. Yes the engine will set in first
    then the gear box and drive lines. Then the cab, I have to build clutch linkage and install steering column which I have to design once cab is on. There is a aluminum diamond plate cover the runs from the
    tail lights to fifthwheel that covers the rear frame and polished diamond plate will cover the rest of the
    frame from cab back to fifthwheel.
  14. Labparamour
    Sep 6, 2013
    333
    Washington
    That looks sweet: frame rails and light turned out so nice!
    Beautiful work....as usual!!
  15. DMiller
    Feb 22, 2010
    5,073
    Retired
    Kinda curious as to the cut off sitting in the back row?
  16. Truck Shop
    Dec 8, 2015
    2,209
    SE Washington St
    That's is what is left of one of our 2011 Coronado's that was wrecked over four years ago. The transmission is in the tow truck and the engine Series 60 14L is one I
    rebuilt and was installed in a glider.
    DMiller likes this.
  17. DMiller
    Feb 22, 2010
    5,073
    Retired
    Meant to ask earlier, old mind keeps getting distracted!! SQUIRREL!!
    Did the frame shop make up the Crossmembers and frame brackets as well? Excellent appearance.
  18. Truck Shop
    Dec 8, 2015
    2,209
    SE Washington St
    No I just had the crossmembers formed along with a 12"x2" lip 90* for flanges. I cut, fitted and drilled all pieces myself, every part and piece was designed on paper before
    I ordered the frame rail and every part and piece fit. Measure three times then cut and drill. I have been making crossmembers like that for years.
    Camshawn, RZucker, DMiller and 3 others like this.
  19. Truck Shop
    Dec 8, 2015
    2,209
    SE Washington St
    One tank done one to finish, J-mounts painted and installed on frame-straps painted also. Before and after photos of tanks.
  20. RZucker
    Jul 7, 2013
    2,773
    Mechanic/welder
    Wherever I end up
    I don't have the patience to buff aluminum, I would have just acid washed it and called it good. But that's me.
