Mack-Phase Two
Cheap "old" Geezer
BV-that is a fairly popular heat & sound suppressor that's a plastic foil film with foam backing and covered with adhesive. You better have it where you want because once down it's stuck.
Appears as a marine application insulation I have used on older boats for noise abatement, looks quite at home on the cab.
1693TA
Farmington IL
FAA Radar Engineer, (Retired)
Should there be any interest in the stock restoration of the this green 1962 B673ST tractor/truck back to working status, I'll post some photos and history up.
For now this is how the truck looked just before being placed on jack stands for mechanical teardown:
Thanks,
Thanks,
Sure there's interest start a thread to document the process, As far as I'm concerned darn near any old truck being saved from scrap metal is interesting. It's easy to torch one up---
it's damn hard and a bunch of work to save one.
old-iron-habit
Moose Lake, MN
While I own it, it will be lucky to see 2,500 miles. One truck show at Brooks and up for sale it goes.
Will it be at Brooks in 2020? Our ACMOC National show will be in Brooks next July in conjunction with their show. I will be there for sure if I am still moving. I look forward to meeting you and seeing it.
