crane operator
I ran a 870tts for about a year. It had the 138' main (110' also available). These are a 5 section boom, 18,000lbs ctw. Use caution when purchasing used because there is a Grove "update" for the base and innermost mid sections. They tend to pop the weld and reinforcement plate 4' in from the tip side of those sections. The one I ran was within the 10year structural warranty, and there was a repair/ exchange. They are pretty cheap used because of this problem. It really isn't much more crane than your 50 ton, look at the charts. I set some grain legs and did a lot of manbasket work with it. We ran it a lot with only 12,500 of the ctw. mounted, we could road it with a dolly and that amount of ctw. on the dolly. I also ran a gmk 85 ton all terrain, 4 axle, 125' main, 52 jib, 35,000 lbs ctw. It was way more crane. The 870 had all wheel steer (they are available either way) but the all wheel steer system isn't built real stout compared with the all terrain. A used 4070 won't cost much more than the 870. Upkeep/ maintance on the gmk will be a little pricier. I wouldn't say the road speed is a big difference, the 870 topped out maybe 60 (downhill), but average hiway speed is closer to 55, the gmk max speed is 52, but they ride like a car (really), they ride so nice compared to a spring/ walking beam. You can put the gmk anywhere, and the suspension is great for setting up. The gmk are a better buy. You may want to look at the older gmk/kmk 5 axle 120- 130 ton.
