doublewide
Here's my Liddell-Birmingham trailer. I use it to haul my JD 410B and my JD 450E along with other minor stuff. I've always been a little curious/confused about how much this trailer is actually designed to carry. It clearly lists the Gross Vehicle Weight Rating as 26,000 lbs. But, it also lists the Gross Axle Weight Rating as 10,000 lbs with 2 axles. It also lists the frame rating as 20,000 lbs. So, which is it 20,000 or 26,000?
It also lists the tires/wheels as 16.5" load range E. If you add up the load rating on the tires, they barely make 20,000.
