Liddell-Birmingham
Discussion in 'Trailers' started by doublewide, Dec 30, 2018.
  1. hosspuller
    hosspuller Senior Member
    Aug 28, 2014
    1,023
    North Carolina
    You said the springs were a xxxx to install. How did you do it ? A special tool ? or pliers and grunt ?
    I hate springs, fight them off and fight them on. And if you happen to lose your grip on one, it flies away from you to hide in the grass or corner of the shop. :(
  2. DMiller
    DMiller Senior Member
    Feb 22, 2010
    6,955
    Retired
    There has been a trick to this for those without the tooling. Install lower shoe get cam roller into the bottom of the S, hang the upper to the spring to the lower and swing it into place then use a pry bar to align and set the Anchor pin. Use leverage where you can. Can do similar hang upper and swing lower into place on the spring, whichever works best for the application.
    PS Mind fingers in pinch points when do this.
    hosspuller and doublewide like this.
  3. doublewide
    doublewide Senior Member
    May 31, 2015
    327
    MA
    At first I was using a bar with a shallow hole drilled in it to hook the end of the hook on the spring. That worked ok as the spring wouldn't slip off as easily.
    I was concerned about deforming the hook so then I started using a stiff scraper knife to slide in between the last two coils of the spring and then prying on that with a bar and both hands and a screw driver and my knee... and..
    I was actually thinking just what Mr Miller just said... 20191127_121312.jpg
    hosspuller likes this.
  4. Nige
    Nige Senior Member
    13,906
    A trick my old man used to use on brake shoe springs was to put the spring in a vice, and then to force a washer in between two coils, then repeat as many times as needed to stretch it in order to get it into position. After installation pull the washers out one at a time and Bob's your father's brother...... :cool:
  5. petepilot
    petepilot Senior Member
    Jul 7, 2018
    948
    central shenandoah valley va,
    I was wandering when someone was going to tell him how to do it o_O
    DMiller, Mother Deuce and RZucker like this.
  6. doublewide
    May 31, 2015
    327
    MA
  7. DMiller
    Feb 22, 2010
    6,955
    Retired
    Looks kinda Broken!!
