Ok I see the video now thanks
That's not my video, just one I found. I actually videoed it all step by step instead of just instructions at the end. It took my about 6 hours all told but, I also changed the oil and did a couple other little things. I could probably do it in 3 or so, start to finish, now that I've been through it.
Blowing it out isn't going to do it. Even if you blow all the dirt out of the evaporator, the way this goes together it's going to end up in the blower fan and just end up right back in the evaporator as soon as you fire it back up. I don't even think the foaming cleaners will handle this because of how it goes together. This is one that requires you to stay on top of filter maintenance or set aside 1/2 a day every couple of months to tear it down and clean it properly, depending on your use.
