Kubota SVL75 Air Conditioner
Discussion in 'Skid Steers' started by cfpd267, Jun 21, 2019.
  1. cfpd267
    cfpd267 Member
    Jun 21, 2019
    11
    64020 (Concordia, MO)
    Hey guys, new to the thread and have searched and searched! I just recently upgraded from Bobcat S150 to Kubota SVL75. Love it so far but the A/C is lacking. Filters were filthy when I bought it so have those ordered. I move the lever all the way to cold and push the ac button and it gets semi cold but does not seem like it blows very hard. I am going to see what these new filters do as well as clean the condenser. I have not gauged the refridgerant yet but plan on doing that this weekend. Anything else I should look for for problems or anywhere else I should look for answers and/or solutions.
    Thanks!
  2. mowingman
    mowingman Senior Member
    Jul 11, 2010
    480
    north Texas
    If it is setup like the 95 I ran last summer, it will have 2 filters. The first one is changed from outside the machine. It can often plug up twice a day. The other one is behind the seat. It also plugs at least daily. The third problem is the AC itself. On the 95, it was just plain weak. I don't think Kubota has figured out how to design a good working AC system for hot dusty weather. Keep those filters clean and hope for the best. Skid steer AC is not one of their strong points in my opinion.
  3. heymccall
    heymccall Senior Member
    Feb 20, 2007
    1,646
    Monroeville, Pa
  4. cfpd267
    cfpd267 Member
    Jun 21, 2019
    11
    Thanks! Sorry for a repeat. I searched and searched on here and nothing would pop out at me. Thanks again! Will try a few things. Agreed. I think all skid steer ac are lacking, however this one just plain sucks.
  5. heymccall
    Feb 20, 2007
    1,646
    Monroeville, Pa
    Post above should've said "will suck air and DIRT" around entire trim panel.
  6. Paul Council
    Paul Council Well-Known Member
    Oct 12, 2018
    239
    Somewhere
    One thing that you can do is to install shut off valves inline with the heater hoses. The air is blown through the heater core first before it gets through the evaporator. If the valve that supposed to shut out the coolant leaks by it will negate any cooling from the evaporator core. It doesn't take much heat to stop the cold. I hope this helps. Good luck.
  7. southernman13
    southernman13 Senior Member
    May 13, 2008
    574
    Retired
    Florida,Ga,Tn
    We have a 95-2. The ac doesn’t blow hard. Never has but it will keep you very comfortable. Ran it today with a Diamond mower on the front. It was actually cold in the cab and the hydraulics never get hot. We’re in SW Ga. it was quite warm today.
    cfpd267 likes this.
  8. cfpd267
    cfpd267 Member
    Jun 21, 2019
    11
    Thanks, I am definitely not a mechanic so bear with me. Which hose would be the correct one to put a shut off on? Do I do just one or both? Thanks in advance!
  9. Paul Council
    Oct 12, 2018
    239
    Somewhere
    I normally do both because it can be difficult to figure out the flow. Especially on a skidsteer.
  10. heymccall
    Feb 20, 2007
    1,646
    Monroeville, Pa
    Shutting off one is sufficient, and, it doesnt matter which one.
    But, my Kubotas will freeze you out, once the cores are cleaned. Cleaning would last about 250 hours, and then the cores would be plugged, or nearly plugged, again.
    Sealing properly the rear trim panel is the key, including adding a bar across the bottom three bolts, to prevent the cover from bowing between the bolts.
    Again, the evaporator will be clogged, not the condenser.
    cfpd267 likes this.
  11. heymccall
    Feb 20, 2007
    1,646
    Monroeville, Pa
    Oh, and inspect muffler support plate. Kubota sells a reinforced one, but, I chose to fix what I had. Screenshot_20190621-201008_Photos.jpg
    cfpd267 likes this.
  12. heymccall
    Feb 20, 2007
    1,646
    Monroeville, Pa
    And why you should add a filler neck screen. Screenshot_20190621-201156_Photos.jpg
  13. cfpd267
    cfpd267 Member
    Jun 21, 2019
    11
    Thanks for the info. What is the easiest shut off to use and do you put it right where one side will thread in?
    Also, The evaporator is located where on the svl75? Is it the item that is on the top of the back plate that lifts up? and do I Seal from the inside or from underneath? As well as where the bar goes for the bolts?
    Thank you for your help so far. Further than I have gotten anywhere else!
  14. heymccall
    Feb 20, 2007
    1,646
    Monroeville, Pa
    140 distorts at bottom. I put metal strap across bottom via 3 screw.
    Because, the filter housing isn't directly connected to HVAC box. Stupid, really, but, that's what it is.
  15. cfpd267
    cfpd267 Member
    Jun 21, 2019
    11
    Okay, so I have cleaned both the condenser and the evaporator. Both were filthy. I have added new filters, re sealed the above housing. And added new vents. I still feel like I'm not getting what i should. I guess my last resort is to gauge the system and see if it needs to be charged. Anything else anyone knows to look for? I plan on taking it all apart again and cleaning again but am running out of options. Just feels like its not blowing as hard as it should and doesn't feel cold all the time.
  16. southernman13
    May 13, 2008
    574
    Retired
    Florida,Ga,Tn
    As said ours doesn’t blow hard either. Feels like it’s on med fan to me. It’s been that way since day one but it’s cold!
  17. cfpd267
    cfpd267 Member
    Jun 21, 2019
    11
    Okay, guess I'll try charging system next.
  18. heymccall
    Feb 20, 2007
    1,646
    Monroeville, Pa
    "Doesn't feel cold"?
    Before messing with the charge amount, what is the outlet temperature?
    What is the low side pressure?
    What is the high side pressure?
  19. cfpd267
    cfpd267 Member
    Jun 21, 2019
    11
    Checking that tomorrow! Will get back to you
  20. hosspuller
    hosspuller Senior Member
    Aug 28, 2014
    970
    North Carolina
    Add inlet temperature to the list that you're checking.
