Truck/ trailer combo:
Truck seems to run great. Valve cover gaskets and new grommets for the valve cover bolts have tamed down the oil leaks. Got the engine brakes working (hold really well too).
The trailer is actually pretty easy to hook up and unhook. I had planned on building a pinning trailer, but I don't think I could pin and unpin as quickly as this loads and unloads. Still learning to keep my truck straight to the trailer, when I drop, it makes it easier to hook back up.
As far as the issues with the trailer-its a used trailer. I didn't want to spend $60-80 grand for a new trailer. Most used trailers that age (mines a '96) , they want $28-35,000 used.
This 1996 talbert brought 16,000 at auction by me, and it had serious problems (and it wasn't long enough or a triple axle):
https://www.purplewave.com/auction/160915/item/K5736
So I guess I could have had that mess instead of mine.
I gave 17,500, spent a $1,000 doing bearings and seals. The shaft I'm now replacing is only $100. And a day and 1/2 tear down.
I'm still under $20,000. Rubber's pretty good, brakes have got some shoes left.
I still think I did okay. It could use a paint job, and a set of spring brake cans (no spring brakes right now, only has parking brakes until the air bleeds away).
I think it will make it much easier to use the crane for more sites, if I don't have to call someone else in to haul it, for a 4 hour job.
It is 102,000lbs, 10' wide, with a 51' long trailer, so its not exactly fun driving around, but I'm happy.
RT :
It doesn't have much outrigger power, you can't just three legged it. I need to check that relief setting (jacks). It works like it is though, and I've been too busy to mess with it.
That said, the rig is almost balanced, not boom heavy, or counterweight heavy, so you really have to swing and tip it, to jack up very high. I've only got 16 wood blocks on it though, and I've been in some pretty crooked spots and not needed any extra wood, its got quite a bit of stroke on the jacks.
The hydraulics seem kind of strange on that rig. Some things-like boom up and down are really fast. Rear steering works great, front steering from the wheel is weak. Jacks are weak. Swing is slow (acts like gearbox drag, or spring pack). Telescope and winches are great.
When I write it all out like that- it looks like a bad section in the pump, but I know the steering has it's own pump, not sure how everything else is separated out. Winter projects.
