Hey Boone, Ive been tied up an off of the forum the past couple of months but jumped back on to see how you wound up with your starting issue and see you have dug a water line from Tennesse to New Mexico! -LOL! That looked like a job! How many feet/yards was the water line dig.?
LOL, you're missing out on the latest news! I was hoping the machine would behave on that job, I was a bit nervous on the starting issue not knowing what might manifest itself after hours of use, but it did great. The owner said it was a half mile of trench, but not sure if that was driveway or as the crow flies. It was a long way though. I'm just thankful we didn't hit bedrock or multi-ton boulders.
I talked to the owner Wednesday night and he said he finished up the water all the way to the barn and has 42PSI of water pressure at the barn. I can't remember what he said he started with on the road. He was thrilled that he didn't have to add a booster.
Also was your starting issue really only starting it on low idle and not 1/3 throttle up? I still start mine on low idle.
Yes, the issue still is that it will not start at idle - well it starts fine, it just want stay running after a sec or 2 when it has sat for a day. It's still a mystery. I thought it was electrical, thought it was the pump, and now I'm thinking it might be an air leak on the inlet side. Not sure if you've noticed, but the fuel line is a hydraulic line. $180 OEM online. Mine is a really corroded at the top of the tank, but it's not flaky. I also primed the pump yesterday listening for air, but all I could hear was fuel going back to the tank - I presume from pressure at the pump to return line.
I'm not sure what I'll do at this point. Part of me wants to drop the tank and inspect the pickup tube and the tank and replace the inlet fuel line. I've thought about just running rubber fuel line with a hose clamp to see if it's the line.
The other part of me just says to run it the way it is and fix it when it gets worse.
I haven't tacked the leaky cylinder yet but have finally got that log splitter re-engineered and beefed up--and it works. I will have to post a pic of that. Good luck!
Did you beef it up yourself or did you have the fabricator do this? I'd be interested to see it. Did you ever get your shop finished?
