Haven't cranked this machine in about 3 weeks. Even with added throttle - this time, it failed to start. It finally started after about 20 sec off and on the starter. Between cranks, I checked the lift pump and it was pegged out with pressure. I could also hear fuel going to back into the tank from the return line. So I'm fairly confident the IP was getting fuel.
To recap from the last page - new lift pump, new fuel filter. I cut the old one apart and found no hint of trash. Removed top of IP and checked the glass ball, blew compressed air thru it, it seem to be working. I blew air thru the return line - could hear bubbles in the fuel tank. Did find the shut-off solenoid housing was cracked, but seemed to be working.
SO...I removed the injectors today. They were DIRTY. I'm planning to remove the IP pump and have it rebuilt. It has the tapered shaft with a woodroof key. The service manual on the engine says nothing about timing the engine or the pump on removal or install...only to ensure the timing mark is on the front plate and the pump flange. I scribed a second mark as insurance. Just wanted to confirm no timing or locking needed before I remove this Stanadyne DB4429-5303. Thanks.
In case anyone references this in the future, no need to remove the exhaust or the air box.
