Hi everyone,
Small update and question:
The machine has been running pretty well with the new diaphragm, and I'm able to get full RPMs while driving. However, I'm still not getting the power I need when pushing into a pile and scooping up the front end loader.
Basically when I've got it in first, I'm pushing into a pile, the RPMs sag, and I loose power. I presume this is because the turbo boost has let off.
'pumpguy, are you still out there? We've touched on the adjustments one can make in the boost diaphragm assembly, but what are these actually doing?
What I think I need for my situation is more sensitivity, i.e. that the boost starts happening at lower pressure, so that it's boosting when the RPM's otherwise start sagging. I noted that the diagrams say that there is a screw adjustment of some sort--is this adjusting the preload on a spring that the diaphragm pushes on, and it can be softened?
I imagine there is also an adjustment for how much boost you can get, i.e. a limit stop on the fuel, and it sounds like the shims would perhaps do that.
Anyway, before I open it up again, I thought I'd ask.
Thanks!
