Hi All,
An amateur mechanic here.
I picked up this machine at an auction and am just getting into 'er, resolving things one by one.
1998 JCB 217, USA model with "AK" series Perkins 1004-4t (turbo), rated 92hp, (though Perkins says 111hp)
I'm not sure which injector pump (yet).
The machine runs okay under no load, and even with some load, but when I really load it up, say by going up a steep hill or trying to push into a pile of dirt, it won't develop the power, which is to say the engine RPM's aren't coming up with the throttle.
Under it load she does throttle up as expected, though the tach isn't working right (yet).
As best as I can tell by diving into manuals, is that there is no computer or anything regulating the RPM's. All there is, is the governor, the fuel, and the air. I put in new air filters (the old outer filter was pretty clogged). I haven't put in new fuel filter(s) yet, but the machine has the type with a glass cylinder and a drain port, and from the manual it looks like there is also a filter element. I will go through those next. As far as I can tell though, the glass is always full, which tells me the lift pump is working. So I don't know that cleaning it will particularly make a difference. Let's assume not, and that the injector pump is getting all the fuel it wants.
So my question to the gurus out there, is what then?
Again from the manuals, what controls the fuel is a combination of the governor, and it apparently has a turbo boost control which cuts back the fuel at low boost. Just talking through it: I'm guessing the governor works, since I can generate suitable RPM's at low load. However, if the turbo isn't boosting, then the fuel won't come up. I suppose the turbo could be bad, or the boost connection isn't working right (is it a pressure line, or electrical? Couldn't find more info. Unfortunately the machine is out in the field, so I'm back and forth).
Can I disconnect or bypass the boost so the pump will give full fuel?
Is there some way to determine if the turbo is boosting properly?
Could there be an issue with the governor?
Other things to check?
Any advice appreciated.
Thanks!
P.S. as an aside, why does Perkins rate this engine at 111hp, and JCB at 92hp?
Thanks!
