From your attachment 5372 above - is the gear #13 in the illustration listed as a quantity of two.? If so that's the pair of gears for the second section of the pump.
What's inside the converter appears to be a magnetic screen assembly from the parts illustration. In technical terminology that assembly is designed to remove "dogs, small children, & tree branches" - a filter it ain't..........
Is there another filter housing in the lines between the circulating pump for the converter and the cooler.? Upload the parts listing for the lines if you have it.
Where exactly was the magnetic screen located that you found plugged up with particles.?
Regarding "what gets filtered where", all the oil that is sucked by pump #14 is sent through the filter #2 before it goes anywhere, be that transmission, steering clutches, or converter. Everything else in the way of oil that is moving anywhere within the system after filter #2 at best goes through some sort of a screen, magnetic or otherwise.
Do you have any parts manual pages that show the power train oil lines (transmission, converter, cooler, whatever).?
