funwithfuel
Recently a newbie asked a question about hydraulics and cross contaminating oil with fuel. Long story short, I and others were challenged on the subject of "Dieseling" I was also accused of being a google technician. I really don't care what you guys think of me or my experience. I DO want to point out that dieseling is a real situation. Attached are images of the barrel to head as being separated . The pics are of a dipper cylinder of a 158,000 pound machine. It sits up pretty high. Very difficult to purge air out. This is what happens . I challenge you to find these images on google or tineye or any other image search engine. They are my pics, shot with my phone. I really didn't want to get drawn into a petty argument like this. The pressures were set to spec, the machine was not digging heavy clay. It was strictly material handling, mulch, to be exact. This was not a hard working machine, nor was it abused. We replaced the first cylinder under warranty with less than 700 hours, the second , a couple hundred later. Upon disassembly of the first, we discovered the back up ring and O-ring were both disintegrated. The piston packing was burned and forced back past the ring lands of the piston. The internal seals were also deformed badly. It didn't take long to realize what happened. This was a newer machine, after repacking the first cylinder and replacing the replacement as well as diligently purging air from the circuit , no new leaks have been reported. It has been over 2 years without failure.
MODS, If this post is viewed as inappropriate, please delete or modify as needed.
