diamondtguy
I got the other side done this morning before the rainstorms hit.I have 6 mounts in there.Each mount has a shear strength of 85lbs.That should be more than enough to support the rad and vibration.Lateral movement is quite good.Hopefully this solves the problem.I will find out the next time the temps drop..
Forgot to cut the corners off but I can do that later.
