Operator4100
Hey, goy up this morning and got to looking on the www, and found this don't know if you have seen it, lots of info, DW
https://freecranespecs.com/P-H/430A-TC
we will make an operator out of you yet.
I think you should practice a bit with the crane and the multi part line before you start using the jib.
One can hope.
My issue with the swing brake is that it hardly holds at all. Say I swing right 90 degrees, use the left swing clutch to slow/stop myself, set the brake and start booming up/down eventually I'll start swinging left because the clutches that was last used drags. I think I just need to figure-out how to tighten up the brake a bit and work the machine to try and get the crud burned out of the friction elements. It was a bit disconcerting the first time it did this.....
Next I need to see about making some outrigger pads and getting some slings and rigging.
I wish I had a 10' boom section, I kinda like the 50' boom load chart better than the 60' boom for some machinery I'm going to have to unload from a truck.
Nope no outrigger pads, not even any feet for the adjustment screws on the outriggers, will need to make something so they will be able to bear on the pads.
What do ya'll like for outrigger pads? I'd imagine making them round would make them easier to move around, but be simpler and provide more bearing area to make them square. I was thinking of a 4'x4' square of 3/4" treated plywood sandwiching treated 4x4's. Heavy enough?
Hey, I bet your 2 pawls aren't catching right, one or the other should catch the boom hoist drum remember those have to be free on the pin they are mounted on. Dw
It might pay to backtrack to the auction yard and original owner for the outrigger stands . Probably laying around somewhere ?
Would go with oak or hickory myself
I doubt it. The guy that towed the crane to the farm for me was the guy that towed it to the auction yard. He wouldn't say exactly where it was from, but apparently the machine was sold due to a back foreclosure, along with a bunch of other machinery.
