Got the boom tip, jib and a 20' section moved this week. Plan is to get the last 3 30' sections moved this week.
But more importantly, boom down works! Just needed some more weight. Hung the hook block on the tip of the base and that worked like a charm. She started to break free with use, I think it was just stiff from sitting.
Also the outriggers now all work. It looks like the PB Blaster I sprayed all over them were what was needed, one is still a bit stiff, but I think it'll get better.
Got the 20' boom section pined on today, with needing weight on the boom to lower, the lowest I could go was about 5' off the ground. Made mounting the boom 'fun', had to once again call on the old Hyster. It's a plain mast machine unfortunately, no fork positioner or side shifter. So got as close as I could driving up to the boom (about 6") then used a come-along to drag the 20' section to the boom tip and pinned it in place.
Now, stupid question time once again;
Next time I'm at the machine I'm going to try and get the tip and jib mounted and the hook blocks all reeved. Anyone got a picture or explanation about how the hook block is supposed to be secured. Revving it is pretty self explanatory, what I need to know is how (and where) the end of the cable is secured.
Also what's the deal with the extension cables for boom hoist. I understand that the bridle (think that's the right name) will need to be unpinned from where it's currently attached and then pinned to the long cables that are in turn attached to the tip of the boom. My question is, are there a specific cable I need to use to do this or just find one that's long enough? I've got two or more for about every boom section, will I have to join any together?
Stupid pictures aren't coming out in the right order, but you get the idea.
I also was doing some googling and found this;
https://cranenetwork.com/details?id=170185&pn=cranes
Pretty interesting, kinda amazing they paid that much for my machine and then it somehow made it to Houston. I wish I had the bumper weight, wonder why it got separated from the machine, but that's not a big deal to make. But something is weird with the listing, they are either using pictures of my crane (identical to bend thing on the boom to rust steaks) to describe another machine or just have the info wrong, so can't be sure what's going on.
