transmission gear don't work down the column,, thats forward/reverse/netural shift shaft
the gear shifting works with the shaft coming strait up from the transmission,,,, no wonder it would'n move with it in third gear and 10 degrees. at low temps i extend out riggers and raise rear tires off the ground and let the engine turn the tire for about 15 minutes
i guess you know all this,,, but your descrption confussed me,,,, sounds like water got in thru a hole in the boot,,,, put pentreting oil in the same way
HELP...I need to rebuild a 201 diesel engine in my 73 Ford 4500 Industrial TLB. I've been trying to find a SERVICE manual with instructions on how to remove the front axle assembly with 740 loader attached. The only SERVICE manual I can find, which I already have, is for an agricultural 4500 - tractor only. (Ford 4500 Agricultural Tractor Repair Workshop Service Manual 1965-1975). This manual does not include removing hydraulic lines, etc. associated with the loader and hydraulic pump. I appreciate any information you can provide. Thanks
