First time pulling tranny
RZucker
Wherever I end up
Mechanic/welder
Truck Shop; that is real nice and professional work but in my case doing one, maybe two clutches every two years makes the job new each time. Got to remember how I lifted it last time, where are the eye bolts I made, where did the pilot shaft go, oh I forgot I have to fix all the air lines again before I get it back together and the dang 966B is broke again and another dump truck died in the pit and now the boss wants a brake job done on his pickup and the parts just showed up for the D8H and they just stranded the ejector line on the Letourneau scraper and the pump on the wash plant quit putting out water and on and on and on and on infinitum.
Letourneau scraper??? What have you got there?
mitch504
Andrews SC
Here's some pics I took for another guy on here of how I jack those up. I usually put the truck up on Budd rims and work from creepers.533535419_1885550665_0.jpeg 533535419_1885550665_0.jpeg 533535419_1885550665_0.jpeg 533535635_1885551478_0.jpeg 533535635_1885551478_0.jpeg 533535969_1885552760_0.jpeg
mitch504
Andrews SC
In case you can't tell, that's a piece of 1/2" plate bolted on top of the jack, a piece of 6x6 about 18-24" long crossways behind the PTO, and a short block beside it. The PTO is holding up the other front corner, and there's 2 good ratchet straps across the whole thing.
Personally I drain the gear box and remove the six fasteners and drop the PTO then put a spare cover back on to stop the drips. It just doesn't take that long plus most PTO's
leak so that needs to be resealed anyway. I want the transmission setting directly on the jack plate. Got a friend minus some parts to his hand from doing that same job some
years ago. JMHO
crane operator
sw missouri
I strap and block a lot like mitch504 does, and remove the gearbox like truck shop says, I find its easier with it out of the way. I would have a hard time doing that over the pit, I'm not sure how you're moving the transmission to line it back up and push/pull it back and forth.
Talk about thinking out of the box. Now that is fancy.
Hallback
Aberdeen Wa.
Gyppo tower logger
Nice setup!
I think I am stealing that idea as our new shop has a 50' long pit also!
still learn'n
Kansas
This one is only 15' as the boss didn't want to take up too much room but I wish it was 20' at least or I need to redesign my lift. 50' for trucks would be very nice.
Did you put rails in the sides?
Hallback
Aberdeen Wa.
Gyppo tower logger
No rails in yet. I will take some photos tomorrow as we are moving in this weekend.
still learn'n
Kansas
I like to learn as much as I can before I start a project so I know what to expect and also understand better how it comes apart! Also if it's something I haven't done before I like to look at it and then have some time to think about it. IMG_20180112_094218173.jpg IMG_20180112_094205227.jpg IMG_20180112_094218173.jpg IMG_20180112_094205227.jpg IMG_20180112_094159554.jpg
still learn'n
Kansas
This one I'm working on is a Mack RD688s that we just put bar tread tires on. The guys say it will go thru a lot so far we have the regular steer tires on it but was supposed to get 445 tires for the front yet to. We also have a floater truck like you pictured and also like is in attached photo that we put a tank on that will go thru a lot don't know if we hardly ever have got it stuck. The newer floater trucks have planetary rear axle and ours don't so have blown up the rear end in ours quite a few times.1500581146424_1662554570_94ab3a99.jpg 1500393073446_1486652800_94ab3a99.jpg 1500581146426_4085491085_94ab3a99.jpg
mitch504
Andrews SC
Ha buddy! Your front tires are on backwards.
Nope! Read on the side of a motorgrader tire. Arrow one way for powered tire, other way for unpowered. That kind of tread works like a ratchet, the rear tires grip the dirt good to push the truck forward; the front tires, the dirt grips the tire good to keep it rolling. That truck goes until the front tires stop turning, soon as that happens, you only have a few feet to get on solid ground. In 32 years of spreading, I've tried it both ways, and reversed fronts really work better.
We ate up a bunch of 17,000 lb IH 2-speed rears, once I started running the 23,000 rears, I've had no rear end problems.
I run IH 2375s with 23k rears, low-hole 9spds, and 300hp L10s.
That pic is actually of one I wore out a few years ago, I am still running the same specs, though.
crane operator
sw missouri
Aww come on, most of us know what the tranny looks like, I want to see more pictures of the plate you made, and if it worked well.
That's quite the pit. Steel tracks, lights, electric and air, all right there in the pit. Got stairs to get up and down in too? How about a drain hole or sump in the corner? I've been known to be messy at times and I've always wondered how that would be in a pit.
The truth is most of us are a little envious of that set up, I know I'm impressed. Someone put a lot of thought into that. I feel pretty good that I get to work on concrete, and sometimes even in the building. I've done some of that out in the dirt, and that adds a whole different set of issues, to say nothing of wind rain or snow.
