still learn'n
I am pulling a tranny on a truck for the first time ever the clutch has an issue it's on a 99 Mack RD688S. Any pointers or is there something else to engine, clutch or tranny I should do?
I have a pit in shop I'm doing it over that I put a track or rail in when we did the concrete work and i already made a lift to put in a diff on another truck and was planning on adapting it to pull the tranny so if I can lower the tranny low enough will I be able to pull it with out pulling the shift lever? The shaft is on the tranny and then goes into the clutch right? So how long is that shaft? As thick as the clutch?
Do you just get a clutch from any truck parts supplier or is there one that's recommended?
