I think you're correct. A look at the South Burnett web site brought up this:Phil_C, Iam not sure that the 70ci had a wet master clutch, nutwood will be able to verify.
Our AT7C had an oil clutch which we were able to remove through the opening above the clutch.
We also removed the flywheel through the same opening to replace the starter ring gear.
"In the late 1960’s the 70CI models in Australia had a name change to AT7 (Angle Tilt). Apart from the upgraded track rollers and grease pump up and track adjusters as against spanner adjustment on the 70CI, and better sealing of final drives and as well as oil type master clutch on the later AT7’s there were not many other changes."
