EX120 -> Torn Bucket Repair (Pics)
Discussion in 'Excavators' started by Egetebee, Dec 4, 2019.
  1. Egetebee
    Egetebee Well-Known Member
    Jul 3, 2019
    107
    New England
    Oh, yeah right.
    Thank you,
    E
    DMiller likes this.
  2. Egetebee
    Jul 3, 2019
    107
    New England
    UPDATE:
    Spoke with my local support (who's delayed till tomorrow) and he's said to simply leave the bucket on the machine for now as Tugger2 instructed.
    Today, I'll get the side cutter off by splitting the nuts and will continue cleaning the area up.
    Thank you all,
    E
    DMiller likes this.
  3. DMiller
    DMiller Senior Member
    Feb 22, 2010
    10,306
    Almost Retired
    What have found with heating is removes any entrained or absorbed moisture, that generates steam pocket inclusions and a bit of Hydrogen from the arc process which adds to embrittlement.
    Ronsii likes this.
  4. Egetebee
    Jul 3, 2019
    107
    New England
    UPDATE:
    That worked out very well.
    Thin cutting disc straight across the nut & bolt face. Hammer and they popped out. Cutting edge is off.
    Thanks again,
    E
    [​IMG]
    DMiller likes this.
  5. Bls repair
    Bls repair Senior Member
    Jan 21, 2017
    1,610
    Equipment operator,mechanic
    S E Pa
    Check other side ,looks like you may have crack there
    DMiller likes this.
  6. DMiller
    Feb 22, 2010
    10,306
    Almost Retired
    Yes it does!!
    Cowboyrob likes this.
  7. Cowboyrob
    Cowboyrob Member
    Dec 7, 2019
    12
    Stafford, Va
    Can using the teeth on my bucket to break up concrete with the bucket curled all the way back cause damage to the pins or other parts?
    DMiller likes this.
  8. InsleyGuy
    InsleyGuy Well-Known Member
    Jul 5, 2010
    50
    Howell, Mi
  9. Egetebee
    Jul 3, 2019
    107
    New England
    Hi Cowboyrob,
    You'd most likely want to start a new thread based on this question but the quick answer is...
    Surely.
    Besides the pressure on the front edge (teeth) the pins, support plate welds and bushings are going to take a real beating, especially if you're hammering the bucket down to break the concrete up. The torsional loads on the pin supports are really high when the teeth are used as leverage and cracks may occur at the pin plate welds. Ask me how I know...
    Bottom line, for the most part, the bucket is meant for 'bucketing' not hammering, like a hydraulic hammer is.
    E
    Tarhe Driver, DMiller and Cowboyrob like this.
  10. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    3,544
    s/e Heavy equipment operator
    Western Washington
    Seems like you do it similar to most of the rest of us ;) if you're breaking up slabs that you can lift a corner of just lift em' and shove something under the corner then come down on the center of it with the heel of the bucket... saves you teeth this way :)
    RZucker, DMiller and Cowboyrob like this.
  11. doublewide
    doublewide Senior Member
    May 31, 2015
    680
    MA
    I think it comes down to the machine. Some machines don't like it, (like mine). I have better luck with 6011.
    DMiller likes this.
  12. rmllarue91
    rmllarue91 Senior Member
    Apr 17, 2014
    614
    field technician
    northeast pa
    Buy 7018 for AC if not it's hard to weld normal 7018 AC but possible. 1/8 120 amps or so
    DMiller likes this.
  13. Steve Frazier
    Steve Frazier Founder Staff Member
    Oct 31, 2003
    6,095
    LaGrangeville, N.Y.
    Maybe it's just me but it looks like where the floor of the bucket meets the side could use some attention too.
    DMiller and Ronsii like this.
  14. Egetebee
    Jul 3, 2019
    107
    New England
    Had a good long welding session on Sunday and buried a bunch of 7018. No support plates at the moment but should hold up just till I finish a few more tasks, then pull the bucket off for the winter, get it powerwashed and inside and go for a much more intensive repair.
    Thank you all very much once again,
    E
    DMiller likes this.
  15. Bls repair
    Jan 21, 2017
    1,610
    S E Pa
    No photos?
    DMiller likes this.
  16. Welder Dave
    Welder Dave Senior Member
    Oct 12, 2014
    5,464
    Why not fix it right the first time? I would have beveled if from the outside, pushed it together and welded the inside first. You could put a couple extra passes to add extra meat on the inside. Then grind from the outside into the root of the weld from the inside to insure 100% penetration. Taking the bucket off and putting it on its side would make it easier to weld the outside up. If you have any slag pockets or lack of fusion could be a potential source for new cracks. Preheat around 300-400 deg's. is sufficient.
    DMiller likes this.
  17. Welder Dave
    Oct 12, 2014
    5,464
    6011 would be OK for a root pass but 7018 is superior for this type of repair.
    doublewide and DMiller like this.
  18. Egetebee
    Jul 3, 2019
    107
    New England
    Welded into the dark and it's been raining & snowing ever since.
    Will post a couple photos soon.
    DMiller likes this.
  19. Egetebee
    Jul 3, 2019
    107
    New England
    Simply didn't have the time and needed to finish the remainder of the project this week. The machine will be sitting idle for the winter soon enough with plenty of time to it better.
    E
    DMiller likes this.
  20. DMiller
    Feb 22, 2010
    10,306
    Almost Retired
    Will be a better repair and inspection once you have it back home. Just ignore nothing as to an indication that could be cracking anywhere.
    Ronsii likes this.
