Self-Jameel
I started working on this machine some couple of days back, on the right track if you view the machine from the operators cabin.the problem is all the implement is fine bucket, stick and boom to be more precise but the right tracking is very slow hard to even move on a level ground. Done some couple of troubleshooting such as exchanging the 2 drive Motor,rekitting the center joint (swivel) as well as Interchanging the 2 valve from beneath the operator's pedal but to no avail, tho I didn't check any pressure because on Ma way to the job site My tetra Gauge got smashed on. I rule out the possibility of the main Hyd pump being faulty cos I see all the implement from the 2 pump working fine.pls help but can't get a gauge from here have to back to Nigeria as I'm now in Cameroon. Thanks to you y'all.
