Charging stations numbers are not the problem, the materials level/time required of grid overhaul to support the added stations is.
Sounds like they need to lower the C rate in bulk phase on the (BMS) Battery management system), it can be had. Bet you those are thousands of 18650 batteries which is old tech compare to the 21700 which has 46% more capacity and 15% more energy efficient.
Just FYI it's the same energy density. The numbers of the batteries refer to dimensions. The only difference between the two batteries is a metal tab that improves conductivity.
Increasing numbers of people being concentrated in urban centers requiring more energy for the basics of living. Reduced sources of energy due to a misinformed populace that has lost perspective on what it takes to power mass transit, trucks, cars, house and appliances. In the Northwest, hydroelectric dams and anything that touches a water stream is considered a pollution source. Wind mills and solar plants are considered non polluting. The population conveniently forgets that those sources do wear out and there is a pollution penalty for their removal, destruction and disposal.
