Money, profits, shareholders.
Our emissions with tier 3 reduced PM so much over pump/line/nozzle. The EPA with its overreaching power and legislation by mandate.
I personally carry a grudge with tier IV interim and final.
As mentioned above, derate and shut down for no other reason than your nozzle is plugged, your DEF quality is not pristine or you ran out. Or how bout yer $1800 NoX sensor crapped the bed. No detrimental effects to the engine, no danger posed, the gov't via EPA has mandated that you will repair or suffer to the point of stopping. This is accomplished by software programming. They have decided that you have several operators working, mid-cut, now this guy has to lay his scraper on the side for a forced regen , or to have a tech come out and drain the pee-pee tank refill it and start the whole works all over again. In the meantime your crew all stand around with their thumb up their a$$3$ on the clock costing thousands.
Figure an operator , full package, $125-150 / hr. Now multiply by how many folks on job waiting on the piece of equipment to work as intended.
Some mom n pops dont have the finances to recover from a chronic/ intermittent problem that the "factory/dealer mechanic" can't figure out.
But hey , its ok. DEF is totally safe. Right. It corrodes everything it touches. Containers cannot be made non poisonous. Oh, and you can only handle it with plastic or a specific grade of stainless. So, all these plastic jugs and drums gotta go somewhere, right? But its ok. Nothing but sunshine and butterflies coming out your tailpipe.
Oh yeah tier IV is sooo good.
And a little more, if your tier IV compliant machine sells at auction to a third world or "developing" country, get this. At the port, the local dealer tech will come and delete everything for them, unrestricted/unsilenced air filtration. Unrestricted exhaust. They get a real gain of between 50 and 200 hp depending on machine and engine size. Why do we get penalized for being a developed country.
Now i will quietly step down from the soapbox.
