News...I got news. I got the tractor running this morning. Finally tracked it down to a sticking check valve in the return line from the injector pump.
Here is list of what I went through:
First step was fuel filters, they were clogged with black algae, then prime, prime and prime
Second was cleaning the tank, draining, pressure washing, drying and blowing down the lines between the tank and the filters, through the lift pump. Tank was coated with algae on the inside.
Third, replaced lift pump, because pump was a bit dodgy. Pump was ordered before tank was cleaned, just in case.
Fourth, bleed from tank to injector pump until clean, using the new lift pump, that worked a whole lot better. Suddenly it is four strokes to prime from tank to filters, not 400.
Finally, this morning blew down the return line, then when line was clean but still no flow from return fitting, pulled the check valve and cleaned.
After that, restarted and ran like a champ, let it run for a good 30 minutes just to make sure. I suspect some of the algae might of gotten past the filters into the injector pump.
The stuck check valve was the proximate cause of the problem, but lack of fuel system maintenance, as in black algae infestation, was a contributing cause.
Out of pockets costs for the work...
$31 for lift pump and gasket
$5 for spray cleaner
$50 for 30 gallons diesel
$100 for 4x4 cribbing to hold bucket up for engine access
$56 new fuel filters and one sediment bowl
and $250 for other parts ordered when found to be bad while doing the work, like a piece of exhaust pipe and a valve cover gasket.
Plus an oil change, since the filter had to come off to change out the lift pump, so add $25 for that
Plus, thanks to the wife who after her day job, put on a set of greasies and helped bleed and troubleshoot.
My line wrenches haven't seen this much use in YEARS.
Howard
