I agree, and the boom and arm are not springy like I would expect if they had some air in them.The airation should affect the work of the whole system not just travel!
The tank stays pressurized for at least hours after shutting off the hoe and the suction hose and tubes are oil free.Your suction side supposed to be pressurized ( pressure in the tank regulated by valve in the breather), so any leak in suction should come up as oil stain/leak on the suction pipes.
I confirmed that oil enters below oil level by viewing the fluid inside the tank, while running, through a cover I had removed.All your return flow should enter below top oil level.
Maybe I am wrong, but I thought a tiny amount of super fine brass particles was normal? The particles I saw, it would probably take hundreds of them just to equal the size of a grain of sand. The suction strainer was rather clean, defiantly less than 5% restricted and suction tube and hose are not collapsed. I guessing that should rule out suction restriction.Brass particles might be from piston shoes of the motor or pump. Check your suction - airation and piston shoes damage can come from suction restriction.
After I put things on the hoe back together I worked it on a slope for about 45 minutes, all of the same symptoms eventually appeared as expected. One minute it easily climbs the slope (even at 1,200 RPM) the next minute it can just barely climb the slope and only with maximum assistance of pulling with the hoe arm. Running at lower RPMs delays the onset of the symptoms. The forceful resistance in the joysticks seems to only happen during forward tram or when attempting forward tram, and even when forward traveling down slope. It got dark on me today so I plan to do the IR thermometer testing tomorrow, as I don't yet have the other testing equipment. I believe once I can follow through with all of your testing advice, the problem(s) will be revealed.
I can't thank you all enough for all of your knowledge and assistance.
