How can you "rebuild" an engine & NOT get the inj. pump & injectors tested??
Arent they supposed to AT LEAST get it checked?? The injection system is the most important piece on the engine.!!! WOW..
Even when your getting your tonsils out they check your heart.. [simplest procedure]
The inj. system IS the heart of the motor..
Just something to think about..
Many years back I was surprised to find out the local Cat dealer did not have a test stand to test run an injection pump on after they "rebuilt" one!
We had sent a pump, off a 3306, to them to have it rebuilt while we did the rebuild on the engine. After assembling an engine we always would start and run on the shop floor while hooked to a water barrel to be sure there were no obvious leaks or strange noises.
Forget exactly what we noticed wrong with this particular engine but something was obviously not right. After checking some basic things like valve adjustments we proceeded to swapping fuel nozzles, or as Cat calls the prechamber ones injection valves. Problem stayed in the one cylinder.
I came up with the idea that there was a problem in the fuel delivery so lacking a test stand came up with the idea of using the engine as the test stand. Dug out a good used pair of American Bosh injectors out of a Mack END711 engine and a pair of fuel lines from the Mack. Installed one set on the cylinder in question and one set on a "good" cylinder.
Cranked up the 3306 and let it run on four cylinders while holding a coffee can under each of the test injectors. Yes I was careful to not get fingers near the fuel spray! Did this a couple time to confirm what we were seeing. One cylinder was very obviously getting way more fuel than the other, did not need a graduated test tube to see the difference!
Took pump off engine and personally took it to the dealer and explained what we had done and found. At first they seemed to question our methodology and said they had installed new plungers, at the rebuild, so there should be no problem. Well they finally did pull the plungers out of the pump and just by looking at the size and shape of the scroll on the bad cylinder one could see the difference!
Next thing was almost better. When they checked availability on a replacement plunger it showed as being in-stock but they could not locate it in parts department. That is until someone recalled they had just had an injection pump class a couple days before. Seems the plunger that was "in-stock" was the one they had used in the class and was sitting on desk in classroom. So now our pump was reassembled with this plunger that had been handled by a couple dozen sweaty hands in the class.
Guess the factory had left a good coat of test fluid on it as it worked just fine when pump was reinstalled on engine back at the shop. No idea of the long term operation of the engine but usually our plants would destroy something before a slightly worn plunger would cause a problem!
How about sniffing the dipstick?What I meant to say was, wouldn't an oil analysis test show presence of fuel in the oil?
Don't know anything about that!Chris, service manager @ziegler is pretty confident that they will find out the cause of the engine failure, through trial and error, if needs be. Just have to have faith that they will pinpoint it.Did they check the piston cooling jets to see if they are spraying? That would lock the pistons down too...and it would smoke before locking up.
Somebody didn't put gasoline into the diesel tank by mistake did they?
So here's a couple of observations/questions?
[/QUTE]
- You started off with a counterbore block and now have a spacer plate block.
- The locating dowel at the end of the block is either broken off or cut off. Why?
- Do you have the right head? Early counterbore heads aren't directly compatible with spacer plate blocks, but all that said, it should only affect the oil feed to the rocker shaft.
- The plastic ferrules in the coolant seals have started to collapse. That's a sure sign that things have started to get hot.
CmarkSo here's a couple of observations/questions?
- Has anyone looked at the water pump impeller?
The water pump impeller was, if I remember correctly, steel. I don't remember it being plastic, I would remember that.The service manager may not be old enough to remember that the water pump impellers used to be plastic bonded onto a steel hub. The impeller would break away from the hub and stop spinning. The pump wouldn't leak as the hub would still mate with the carbon face seal.
I would have thought that the plastic impellers would have been worked out of the system by now, but there could still be some out there.
If you're not sure what Cmark is referring to check the picture below. Locating dowel is circled in Green and Plastic ferrule that is starting to collapse is circled in Red.So here's a couple of observations/questions?
