Hello All,
Thank you in advance for your advice!
I recently started working on a farm that has a '68 Cat D4D (sn: 82J450) that had been sitting out in the field for quite a while. I fixed the fuel leaks and replaced the ignition system and starter and got her moving again. Man, it feels good to rescue an old machine.
Now here is where I'm stumped:
The left brake band has been completely used up, all the way to where the rivets are smashed making the left brake useless. I can only turn right. The right side is almost there too. I've removed the inspection/access plates and I'm trying to remove the bands, but having issues getting the pieces of the bands past the steering clutch springs. Any advice on how to remove either the pieces or the springs?
The steering clutch on the left side also feels spungy and I'm thinking while I have the rear end partly pulled apart, should I service/adjust/replace the clutches?
