Cutting windmill blades
Ronsii
Western Washington
s/e Heavy equipment operator
It'll be bigger than the texas a&m bonfire!!!! and with the burning man theme we might even have some burningmen fatalities to compete with texas ;)
kshansen
Central New York, USA
Not sure I want to be down wind of a fire like that! I'm sure the resin those things are made with are not good to breath when burned!
Sberry
Brethren, Michigan
Farmer
What they use to cut it in fabrication work? Super Sawzall? Maybe crunch it with a big hoe and cut it with sharp edge or even one with some special designed serrated knife edge teeth. Cut them to fit, crush in to a dumpster or car crusher. Might make a blade setup from a cutting edge to start with and 2 hoes working together, one with big thumb.
Cheap "old" Geezer
The issue with cutting the blades is not just making considerably smaller, it is the release of microfine glass fibers from them when cut, more cuts more fibers and more eventual directly associated illness. Silicosis is one, same symptoms as Asbestosis, can resolve to full blown lung cancers, skin irritant, must wrap workers in tyvek suits respirators or outside filtered air delivery systems. Large chunks buried mostly intact least human issue beyond the burial site.
I'd figure out a jet cutter on a hoe, over a portable pan setup. Put big sawhorses on each side and drag the blade across the work area. The slurry contains the bad stuff and you can vac truck it up. If needed, cut out a piece on top to make a window to cut the bottom without flipping over. No dust, nobody touches it and the vac truck dumps that nasty into an inert fill.
treemuncher
West TN
eatin' trees, poopin' chips
I know this is an old post. I wonder if the contract ever came through? I've also seen the Facebook memes regarding this "not-so-green" part of the green energy solution generates in landfill consumption. These windmills also generate a lot of waste oil in their lifetimes, too. Not really as green as they are touted to be but then, sheep are non-thinking creatures that is easily led about through manipulations of unicorn fart inspired ideas designed to sway the masses.
Everything that I know about water jet cutters is that they are very SLOW and expensive to maintain. Unless it was a stationary unit mounted to the blade or ground, I doubt it would be feasible to operate with a hoe. Too much precision required with this method to allow a hoe to keep a cut going. Using the hoe to manipulate the pieces to a set saw system should work with a fluid coolant & contaminant containment system.
A stump grinder attachment or a quarry saw attachment on a hoe might work but too much residual dust would be produced to be a safe solution unless it had a high flow flood coolant system.
Something medium slow cutting with minimal dust production should be best. A slow operating, hydraulic guillotine type device or shear system with misting coolant spray in an enclosed chop chamber would likely be the best option for a long term contract with these blades. I should think that a Vee shaped blade with serrated edges would be effective or multiple Vee tips depending on force required to penetrate the medium. Mount that on a system like a car crusher frame where the turbine blades could be dragged through with a hoe, cable drag system or feed table and use the hoe to handle the resultant pieces to load out trucks or trailers.
Like a customer once asked me, "Can you build that?"
My response was, "Throw enough money at a project and you can build anything."
Tugger2
British Columbia
The wire saw sounds like the most practical idea,it was my first thought . But as a crane owner id take a set of 48" box leads and run a guilotine made from 6" plate with some extra thickening on them ,something up around 8000 lbs . My 75ton would eat that stuff up quick
KSSS
Idaho
excavation
I didn't take the job. My plan was to use a high flow wheel saw on a skid steer to cut it down. I planned on wearing a respirator, replace the cab filter after the job. I wasn't overly sure the wheel saw would work, although I felt it would, I just didn't want to become an owner of blade if it didn't. If I get a chance to try it out without the price of owning the blade if it didn't, I will try it out. The hills above me are loaded with windmills. Someone is going to have do something with the replacements.
ianjoub
Homosassa, FL USA
What about the shears that the steel scrappers use? I know years ago we had an outfit come in and chop up a bunch of scrap steel around the quarry. Their's were mounted on the end of an excavator and seem to recall they worked just like a thumb on an excavator.
<iframe width="560" height="315" src="
" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Mike_IUOE
St Louis area
Operating Engineer
We use a Kinshoffer demo shear for building demo. They cut through steel, concrete, just about anything. They just chew through it. I would think it would make quick work of fiberglass. One of these on a 490 you can process a lot of material fairly quick
Cheap "old" Geezer
Chewing thru is the problem, as in the video above no matter the added water cannot control the dust release, would have to immerse the cut line under water to effectively control dust/fiber release and yes there are construction workers in Demo that are now suffering from Silicosis.
Then there is what are they to do with all the excess debris? Placing within concrete just worsened the Demo contaminate issues not in long fiber form so is pretty well useless for new blade mat materials, still ends up a landfill residual.
The good thing is it is truly inert once buried so they could make some decentralized landfills for them. No groundwater issues, etc.
