In general there are two methods of producing an anti-wear additive package in a hydraulic oil. One is to use zinc, the second is to use a combination of other elements, mostly calcium, phosphorus, & sulphur to achieve the same end result. The latter group is what's usually known as "ashless" or zinc-free oils, because surprisingly enough they don't contain zinc. One of the downsides to using zinc as an anti-wear additive is believe it or not corrosion, basically it attacks all yellow metals to a greater or lesser extent depending on the level of zinc additives in the oil. There's a lot more chemistry to it than that, but effectively that's the short version.
It's generally not recommended to use an oil with a zinc-based anti-wear package in a system that was designed by the OEM from the get-go to use ashless oil.
