Just a few snaps of things happening lately, the first pic is the old and the new chariot with the back-up unit (Jeep) in my Garage, then a CAT D7 top pinion strip out using the 28lb hammer through my never fail flogging bar 1"1/2 drive and pancake 50 ton cylinder, the clump of old track loaders I am stripping parts off to keep working tractors going, the green 1 is Ex Fenton Plant Hire from Hook Hampshire, the D8 was just a quick brake adjust job and look round, the little swinger was an oil leak job (track pilot spools) 211B is a scarce beast, then the front wheel job on the Komatsu D65P, I had to call in a pal to patch in some 8mm wear strips into the frame to replace the knackered bits, oh and the blade patch up on the D8K, as you can see its nearly done with just the right wing to lash up, the vertical strips I had to leave on as the owner said they still have wear life left, the centre plate was shaped to hook up to them? I think this job has taken around 3 days to this point to do.
tctractors
