Caterpillar jumper cable ends
mljohn
USA
Has anyone sourced out the cable ends for the newer cat jumper cables?
Cat does not break down the assembly to identify the ends.
I'd be interested in this too. We did get a set of the Cat cables for our new 773G as someone thought mounting the batteries above the rear axle and under the dump body was a convenient location:Banghead Not bad if truck has the box up when batteries fail:rolleyes:
One thing I don't understand about the Cat cables is why they made them out of stiff as h3ll battery cable and not nice flexible welding cable:pointhead
If I could find ends to use to make up my own set they would be much easier to handle.
mljohn
USA
I would like to have parrot clamps on one end with cat ends on the other. Yes the stiffness is about as bad as the cost of cats cables.
bigshow
Somewhere.
Cables with a clamp on one end and cat connections on another end are available, our mechanics have them or they made them, don't think it would be difficult to make a set.
mljohn
USA
I would hate to cut up such a costly set of cables if the ends are available to build a set.
When you refer to jumper ends do you mean the ones that connect to the auxiliary start receptacle..?
That's the ones I'm thinking about. I believe all the 24 volt Cat equipment for something like 20 years, or more, have come with stock from the factory. I know we have early 90's equipment that have them.
AndrewC
Miles away
Scissor lifts use the smaller version,electric booms use the bigger version, I've also seen them on electric winches for jeeps, fairly common and should be able to get them quite easy from a local supplier if they are the correct ones.
BB64
Eden, Wisconsin
Electrical Engineer
Ah, something in my field, connectors and batteries... Most electric forklifts, scissorlifts and whatnot use Anderson Power Products SB series of multipole connectors -- color coded & mechanically keyed by voltage. Lots of commercial tow truck / fleet jumpstart harnesses use the SB175. This page links to specs and whatnot. http://www.andersonpower.com/products/multipole-sb.html
Small 12V winches use the SB50 series (some grey & marked SMH); also used on UPS's for computers and I've seen them on electric salt spreaders. Larger winches (Warn, for sure) use larger sizes that are custom colored (red, instead of yellow) but keyed oddly so you have to buy theirs.
Accessories include dust covers and boots, as well as handles -- pretty ala carte so you can put together whatever makes you happy.
They are often marketed as kits, for specific wire sizes -- a quick googling found http://www.powerwerx.com/anderson-powerpoles/, no clue on service, but prices are pretty reasonable and they have the full line of accessories.
Good luck!
Mike the EE
The only way I've found to do it is to buy one set of the jumpers and cut them in half. Put a set of alligator clamps on the cut ends and now you have two sets for the price of one plus the clamps.
JDOFMEMI
SoCal
Andrew
Check the picture in the post above yours. The connector on the right is the Cat one. I need these also. Found out one night when I went to load a 740 haul truck. The battery was dead, and to get to the bolts to remove the lid from the battery box you have to raise the hood, which needs battery power. :Banghead :Banghead
Ta-da ........... 353-5080 Plug Assy. We generally make up our own cables using welding cable as it's far more flexible, as other users have pointed out. Although TBH the cable used to make the Auxiliary start assemblies (00-size starter cable) is much more flexible that that used to make the jumper leads with croc connectors on them.
mljohn
USA
I just cant bring myself to cut up a 400 dollar set of jumper cables. Those ends are out there some where cat is buying them from somebody.
