Caterpillar jumper cable ends
Discussion in 'Shop Talk' started by mljohn, Feb 9, 2014.
  1. mljohn
    mljohn Well-Known Member
    Dec 6, 2009
    105
    USA
    Has anyone sourced out the cable ends for the newer cat jumper cables?
    Cat does not break down the assembly to identify the ends.
  2. kshansen
    kshansen Senior Member
    Mar 11, 2012
    7,987
    Central New York, USA
    I'd be interested in this too. We did get a set of the Cat cables for our new 773G as someone thought mounting the batteries above the rear axle and under the dump body was a convenient location:Banghead Not bad if truck has the box up when batteries fail:rolleyes:
    One thing I don't understand about the Cat cables is why they made them out of stiff as h3ll battery cable and not nice flexible welding cable:pointhead
    If I could find ends to use to make up my own set they would be much easier to handle.
  3. mljohn
    Dec 6, 2009
    105
    USA
    I would like to have parrot clamps on one end with cat ends on the other. Yes the stiffness is about as bad as the cost of cats cables.
  4. bigshow
    bigshow Senior Member
    Jul 17, 2011
    467
    Somewhere.
    Cables with a clamp on one end and cat connections on another end are available, our mechanics have them or they made them, don't think it would be difficult to make a set.
  5. mljohn
    Dec 6, 2009
    105
    USA
    I would hate to cut up such a costly set of cables if the ends are available to build a set.
  6. Nige
    Nige Senior Member
    14,557
    When you refer to jumper ends do you mean the ones that connect to the auxiliary start receptacle..?
  7. kshansen
    Mar 11, 2012
    7,987
    That's the ones I'm thinking about. I believe all the 24 volt Cat equipment for something like 20 years, or more, have come with stock from the factory. I know we have early 90's equipment that have them.
  8. Nige
    Nige Senior Member
    14,557
    They are not standard on all machines, even today. Let me see what I can dredge up.
  9. AndrewC
    AndrewC Senior Member
    Feb 3, 2013
    458
    Miles away
  10. CM1995
    CM1995 Super Moderator
    9,236
    That is a very similar connector I have to power the battery pack on an equipment trailer with electric over hyd. ramps.
  11. AndrewC
    Feb 3, 2013
    458
    Miles away
    Scissor lifts use the smaller version,electric booms use the bigger version, I've also seen them on electric winches for jeeps, fairly common and should be able to get them quite easy from a local supplier if they are the correct ones.
  12. BB64
    BB64 Active Member
    Dec 12, 2007
    28
    Electrical Engineer
    Eden, Wisconsin
    Ah, something in my field, connectors and batteries... Most electric forklifts, scissorlifts and whatnot use Anderson Power Products SB series of multipole connectors -- color coded & mechanically keyed by voltage. Lots of commercial tow truck / fleet jumpstart harnesses use the SB175. This page links to specs and whatnot. http://www.andersonpower.com/products/multipole-sb.html
    Small 12V winches use the SB50 series (some grey & marked SMH); also used on UPS's for computers and I've seen them on electric salt spreaders. Larger winches (Warn, for sure) use larger sizes that are custom colored (red, instead of yellow) but keyed oddly so you have to buy theirs.
    Accessories include dust covers and boots, as well as handles -- pretty ala carte so you can put together whatever makes you happy.
    They are often marketed as kits, for specific wire sizes -- a quick googling found http://www.powerwerx.com/anderson-powerpoles/, no clue on service, but prices are pretty reasonable and they have the full line of accessories.
    Good luck!
    Mike the EE
  13. 95zIV
    95zIV Senior Member
    Mar 12, 2006
    795
    RR Contractor Super.
    Cincinnati, OH
  14. big ben
    big ben Senior Member
    Aug 23, 2010
    274
    Vancouver Island
  15. John C.
    John C. Senior Member
    Jun 12, 2007
    7,614
    The only way I've found to do it is to buy one set of the jumpers and cut them in half. Put a set of alligator clamps on the cut ends and now you have two sets for the price of one plus the clamps.
  16. heymccall
    heymccall Senior Member
    Feb 20, 2007
    1,930
    Monroeville, Pa
  17. AndrewC
    Feb 3, 2013
    458
    Miles away
    Snap a picture and maybe someone will recognize it, I doubt cat makes them themselves
  18. JDOFMEMI
    JDOFMEMI Senior Member
    Jan 4, 2007
    3,074
    SoCal
    Andrew
    Check the picture in the post above yours. The connector on the right is the Cat one. I need these also. Found out one night when I went to load a 740 haul truck. The battery was dead, and to get to the bolts to remove the lid from the battery box you have to raise the hood, which needs battery power. :Banghead :Banghead
  19. Nige
    Nige Senior Member
    14,557
    Ta-da ........... 353-5080 Plug Assy. We generally make up our own cables using welding cable as it's far more flexible, as other users have pointed out. Although TBH the cable used to make the Auxiliary start assemblies (00-size starter cable) is much more flexible that that used to make the jumper leads with croc connectors on them.
  20. mljohn
    Dec 6, 2009
    105
    USA
    I just cant bring myself to cut up a 400 dollar set of jumper cables. Those ends are out there some where cat is buying them from somebody.
