From what you have written I think that what you are experiencing is called "drift". Make sure you cycle the hoe for a bit to make sure that you have purged all the air from the system. If air is not the issue I would guess that the swing cylinder/s may need to be repacked. A fairly common issue with these machines is that the nut that holds the piston onto the rod end will sometimes come loose. When that happens the hoe will "wag" back and forth with gravity like when going over rough terrain.So. Another “few” questions for all of you.
After fixing the hose and filling the hydraulic tank with fluid, I started the backhoe up. It had been plugged in for about 2-1/2 hours at that point. All I had time to do was let it run for a bit while I picked up all tools, tarp I was laying on, and get empty buckets and other junk into the garbage area in detached garage.
Then I just had time to move it from where it was parked to where I normally keep it near the barn. This level ground area is close to barn door which is good for plugging it in when it’s cold. Then it was time to take off for other family stuff.
When I was moving it the backhoe seemed to be easing or weeping to one side. If sitting in the driver’s seat, and looking back at the hoe, it was slowly easing or weeping to the left. Now, that same side is where I replaced the hydraulic line to the directional cylinder.
Is there something else that keeps the hoe steady from going side to side?
Could a pin have broken? Or something similar? And then that created more stress on that old hydraulic line?
When the hydraulic failure happened I heard a somewhat loud ping or bang. Then the fluid started spraying. I just thought that was the initial rupture and fluid under big pressure hitting the underside of the cab floor.
Now I have been working with clay. Because it’s so cold, some of the clay is freezing to the bucket. So this is just a guess, but there has to be a good bit of extra weight in the clay on that bucket and arm. 40-60 lbs maybe? Just guessing. Could be much more.
Not sure. But. Maybe it will all settle out tomorrow after I have had a chance to slowly use the hoe by moving it to both sides after it is warmed up in this cold.
But while moving it, it seemed to slowly seep to low side of machine. Which was the low side of hill I was driving on.
Let me know if you have an experience with a hoe doing that while moving and you think there is something else wrong. Or not.
Thanks again.
If everything is as it should be the 40-60# (and probably a lot more) would not cause the hoe to drift when traveling. IMO, the most common cause would be swing cylinder seals (would be fixed with rebuild/new seals, etc.) assuming that you have purged the air.
