gasifier
You might consider a couple things. One is battery warming blankets and the other is adding a charging port. This way you can put the batteries on charge without having to open the battery box. If you use heavy enough cables it can act as a jump start point.
When I worked at a dealer in the 80s we serviced the Ford diesels. Pushing a big rack body into the shop was not fun so we made jump start rig. We took a hand truck and mounted 2 huge batteries on it and a maintainer. It was kept plugged in so the maintainer would keep the batteries topped off. When we need to start a truck or even a car we just wheeled the setup to the vehicle and connected the cables. Boom car would crank.
You could put a plug like tow trucks use so you just plug it in, start the backhoe and unplug.
At some point you should measure the voltage drop on your starter circuit. Make sure you do not have a loss due to bad connection or corroded cable, etc. This is easy and you will know if things are 100%. In my case is cranked and started fine when warm but a bit slow on a cold crank. Cold as in sitting overnight, not arctic winter cold. I had voltage drops of 2.5 volts on the ground side and almost 1 volt on the positive side. Cleaning connections made it less but it was still high. New cables solved the problem. Cranked like a new starter and batteries were installed. Cables looked fine but obviously not. I did not cut them open.
Thank you for the advice. I just saw this as I’m out here. The CAT is breathing again. I brought both batteries in last night and charged them up full. I also fixed the ends on two smaller wires that connect to positive and negative of batteries. And, when I took the batteries out, I noticed the positive lead on the rear battery was not tight. After I cleaned everything and hooked everything back up it started right up. I had just plugged the plug in heater in about 1-1/2 hours ago. I believe it was definitely a connection problem. Two new eyelets, one on each of those wires, and then having the right tools and getting things clean and tight seems to have made the difference. Now I will see if those batteries keep getting charged up as I run her. I’m currently trying to chase a wire to find out where it goes. First time I’ve had both panels off together. Learning. At 18 DEGREES.
