Philip S King
- Joined
- Apr 23, 2019
- Messages
- 115
- Location
- Alabama
- Occupation
- GC, BC, Mechanical , Electrical, Utilities
036 0042.11
036 0091.02
Can anyone ID these.
Thank You.
036 0091.02
Thank You.
Try using the info from the Click Box thread to erase all the Logged Codes in the Monitor. Run the machine again and if the warning light #13 goes off again see if the CID0042 FMI11 or the CID0091 FMI02 Codes return. Also keep an eye open for the SERV CODE icon lighting up.I have read the click box thread. Just ran again and it faulted . Only two same codes logged.
Low fuel pressure warning. Try changing the fuel filters.Also light nine was flashing.
If you go to the last page of the Click Box thread there are instructions for erasing Codes using nothing more than a couple of short pieces of automotive wire and three Deutsch connector sockets. For a one-off situation like yours a Click Box is not required.I ordered a Injection Actuation Control Valve. I wounder if it malfunctioning could cause the light nine to illuminate. Read up a little on the IACV. Seems a logical step to change it out since it logged the code. I dont have a click box so I will let the codes accumulate. I assume the "!" Light means a code was logged. Since I have no new codes , I assume the same codes are re occurring. But not sure.
You need to be looking for Cat Publication reference RENR5235. https://www.ebay.com/p/19003936276I have the operation and maintenace manual. What would be helpful would be a service manual. I need to understand the relation ship between light 9 and the Injection preasure valve.
