I have 980 g. 2kr01589. Got the machine this summer and have not had real good luck so far we put 32 hours on it and the motor locked up so we got that back together and now I can not get the loader to function right. Take 3-10 seconds before it will start to lift the bucket or curls. Loader arms will lower right away to the ground but then takes the same amount of time to pick the front end of the ground. At a idle when you bottom ou the hydraulics it will stall the motor. I have check the hose clams a couple times on the suction lines. And I can sit and press the brake pedal for a minute and no pressure lights came on the dash. The only other thing that I can think of is that after it sitting for 10 minutes the oil level goes up in the hydraulic tank and when you come back th next day it will be full all the way to the top of the filler cap. Normal or not? Any ideas where to go from here thanks
