237-7350-00Can you post the software number that is in the ECM? Submode 13.
I have visually inspected wire harness to the dash it looks great as far as I see no bare wires nothing to suggest damage at least visually anyway is there a way too test the ECMI wouldn’t condemn the Ecm just yet I would check the wiring to monitor first
Ok will try that in bit I did gps it and it’s only going 2mph full outAnother thought on the sync valve (taps for drive pressure are on top) there are two stems sticking on front side. They are tow valves they have about a 3/4 nut on them and a Allen drive loosen the nut and make sure they are in the whole way don’t get carried away they just go in till they bottom if you loosen the nut and it doesn’t turn in your good
Are the attached of any use.?I wish I wouldn’t have gave all my books to my helper
