pittsburgh cat man
Atta boy Nige Go to sub mode 19
Another side note cat also said about 3 months ago they seen same machine and diagnosed bad ecm then said lights and codes popping up so the customer said he would replace himself and I’m sure it’s not new may be refurbished has no yellow paint on it at allI was just thinking lets do the calibrations again when you do min track speed turn it up till it's barely moving then try the rest of calibrations I was just wondering if it was turned so far down it would effect high speed?
I can’t see any signs of the motors being messed with recently anyway I’m sure the belly pans haven’t been opened on it very recent there was 4 inches of dirt mud built up on them when I dropped them so no obvious signs of recent activity there and my question on speed display I read that level 1and 2 will display 00 for speed until you reach speed above that so wonder if I’m going too slow to register speed at this point I will retest the harness again today I know sensors are good I swapped them out with the engine sensor and got good rpm reading with both so would have to be in wiring if there is problem there or ecm ! My question is I know need reading to adjust top speed for sure but got to get machine moving faster than 1.9-2 mph first so if it’s not reading speed can that cause slow speed problemBack in post #116, you said pilot pressure at max fwd and rev was 200psi. This is about right. I have a feeling it may be just the motors that aren't destroking. I ask again, does it look like the motor adjustments have been tampered with?
Whatever the answer though, we still need to be getting a reading from the speed sensors to adjust things properly.
Got it warmed up as book said and hooked gauges high idle with park brake applied as stated in sub 20 put gauges on charge pressure 435 right forward 0 left forward 0 right reverse 0 left reverse 0 so skipped to stall test transmission only part high file full forward charge dropped to 400 still zero on all other portsGet yourself self some where you have room put it in stall pull it in gear and see what it does the new book says only hold for 5 seconds in full forward
