If you were only losing speed signal only on one side it might be worth a try to swap sensors side to side to see if the loss of speed signal changes sides or stays where it is.
I dunno but I would say that if you have a speed signal not reading it could have everything to do with your loss of top speed issue.
FWIW I would not ohm those particular wires to check continuity. If you have a wire somewhere hanging on by a thread then it could show "good" on a resistance check but not be good enough to pass a signal. I prefer unplugging the connectors at both ends, jumper one end of wire X to machine frame ground, then power the other end of the same wire from batt+ using a fused 3A or 5A test light. If the wire will pass that level of current it should be good.
