Thanks for the pictures. I am going to build a 12' x 46' side shed on to the side of my shop building. After reading your post I just might consider putting in a pit. What are the measurements of your pit. Post pictures of the pit if you get a chance. Does it have a drain in the bottom? Steps going down?
That pit is not used very often, but when it is, its invaluable. It is a little bit of a nuisance in the middle of the shop, but nothing bad to work around.
I will see if I can get some pictures and dimensions for you. My father built it years ago to service ag equipment when he built his 40' x 60' shop. he had oak planks sawed up 3" thick by 12" wide. If I remember correctly, he poured the side walls 10" or 12" thick. It's a little too wide for some cars (I think 4') , and it is plenty long (guessing 20'), but the height is great for me, and I'm 6'4" (I think 5' deep). If I was to build one, I'd make it a foot narrower and half as long. I've never used more than half of it.
We never had stairs for it, but a dedicated ladder stays in the pit. He was able to run a natural drain tile out of the pit, so it could be used to wash the undersides of whatever was parked on it.
Since I have that to use, I've decided not to put one in my shop, but I am planning on installing a 2-post lift. I would definitely use the lift more than the pit, but it would not serve well for heavy equipment. :cool2 The farm place is across the road from our house, so I buzz over there on the golf cart to do my heavy tinkering.
