tctractors
To undo the Drive Cookies can be a fair struggle as sometimes the bolts need a spanner all the way off, plus to crack them free can take a good arm full of power, your engine seems to be in fare condition piston wise, have you measured the piston ring gap,you will need to mark the 2 top rings for TOP position if you remove them, the valve guides looked to have massive wear so will need a new set of springs, valves and guides, also the valve seats will need a trim on the 2 angles, tctractors
